6.1 pulleys . with no p.steering and no a/c
gccuda
5:56 PM
canada
I have noticed treads on 5.7 pulleys. I'm looking to see if anyone has a part # of maybe napa . of any pulley and mount for a 6.1 .im am not using power steering and no a/c.
Check over on fabo, those guys probably know.
Nothing yet . but word is the 5.7 car and 6.1 are the same in the front . which I sure of . But still need some part # help
I don't know if you can do it with the "car" timing cover but with some simple re-arranging of pulleys and a shorter belt I didn't have to have any custom parts. Just a thought...might try just moving around a couple of pulleys and see if you can make an arrangement.
04627851AA is the grooved idler that is required for the PS delete. This will mount to 04593918AA.
BRACKET. Idler Pulley. 04593918AA $46.85
TENSIONER. Belt. 04861660AA $51.17
PULLEY. Idler. 04891720AA $18.63
PULLEY. Idler. 04627851AA $16.47
1 - BOLT. Mounting. Hex Flange Head. M10X1.50X55.00. 06104221AA $3.51
3 - BOLT. Mounting. Hex Flange Head. M10X1.50X130.00. 06104230AA $2.70
2 - SCREW. Hex Flange Head. M8x1.25x34. 06509487AA $2.50
3 - BOLT, SCREW. Mounting, Tension Bracket Assembly To Timing Cover Front, Tensioner To Bracket. Hex Flange Head, Hex Head. M8x1.25x30, M8X1.25X30.0, M8X1.25X30.00. 06104025AA $4.59
So I ordered and in stalled on my 2006 6.1 grand Cherokee block. SHOOT too long . any ideas ? I am talking with FABO as well seems to be a big topic
I did my 5.7 hemi with Mopar parts. They make a kit for the 6.1 also. try this link:
www.bpeusa.com/G3HemiFrontEndParts.asp
ya I looked at them . but seems to be an because of the fact im using the grand Cherokee block . the factory delete is being used on the 5.7 . this one you sent may have the same problem .
The blocks are identical no matter what application. The only differences are timing covers and pulley/accessory arrangements. I believe the grand cherokee engine is setup like the cars.
The idler pulleys just bolt to a stud essentially. Why not make your own? Make a plate to match that base plate, weld a piece of tube with a couple gussets to the plate and weld a plate at the end tapped for the bolt. Then use a washer or two to space the pulley out and give it clearance and bolt it down. I did something similar on my truck motor except the stud I used was already there...just added 3-4 washers and bolted it down where I needed it.
ya seems like a lot of work for what its worth . my thoughts have been is there an offset pulley?
