62 fury poly to 383 swap
jeff edwards
12:17 PM
chilliwack bc
anyone have knowledge on swapping a 383 to replace poly motor? torqueflight compatability etc thanx jeff edwards
Tranny won't work as the poly is the small bell same as the LA block.K member will work with the right mounts.Look up www.engine-swaps.com for more info.
Well, it is fun and frustrating all at the same time.You will learn allot here.
There was a late and early style B engine mount type in '62. My '62 is the early style. The brackets for this style K frame are hard to find. This website and the pictures may be helpful. http://1962to1965mopar.ornocar.com/1962-Dodge-Plymouth-Motor-Mounts.html
I've done this swap many times over the years. If you have any questions don't hesitate to send me a private message. I can't think of any information you might need that you won't be able to find somewhere on the internet. There are a lot of helpful and knowledgeable people on this site.
I recently did just what you are talking about on my 62 fury, I changed to duals also. Other than getting a cable shift BB 727 everything else was straight forward.
Drive shaft fit right in. You will need a BB radiator also. Throttle cable was also no issue.
I do have a correct 727 if you need one.
I can get you the top rad hose # .
As a bonus I do have a pair of new dual exhaust tail pipes. They would be from the muffler back.
Let me know. I'll help you.
Nothing like having a 383 BB.
Steve
