WTB 62 Plymouth Taillight Seals
Stumper
12:52 AM
Bandana, NC
Feedback: +0 / =0 / -0
Looking for some of the rubber seals that go between the lights and body on the 62 Plymouth B bodies.
Detroit Muscle Technologies have these as well as other gaskets for '62 Plymouth. detroitmuscletechnologies.com. 586-777-7176
DMT carry the lense to light gaskets but not the light to body seals, I checked.
Get a sheet of gasket material, and cut your own. When you have a rare old car, sometimes you have to do it the hard way. Gaskets are few and far between for my 33 too.
The seals are “U” channeled rubber that fit around the base of the lights not gaskets. If I have to Jerry rig them I wouldn’t use gasket material.
Joe Suchy carries a "U" shaped rubber gasket that fits the 1964 Polara large bezel to body. It will be more material than you need, but might be the right contour. Joe would likely send you a small sample to confirm shape.
Ill check with him. I believe the bottom edge of the 62 bezel is around 1/8” think - not more than 3/16”.
Try Restoration Specialties & Supply, Inc. They have a web site They have u channel and other items for our cars.
Thought I’d put up a couple pictures of these seals in the event someone has them laying around not knowing what they go to. There are actually two types. The one on the left is uniformly flat and are used on the very outer taillights for all 62 B body Plymouth’s. The one on the right is raised more on one side. These are for the inner lights that have an angled base.
I can use either!
