64 Fury Drum Brake Parts
rockauto.com
If you have one already! It can be rebuilt for less money! I had one done for a 70 Imperial a while back, cost around $100.00 +shipping both ways! Can't remember the outfit! It was in Pa. I'm sure there others.
135 bucks, 95 if you send your old one back. But the question was, where were we seeing boosters in stock, not what the price difference to rebuild one was.
I am looking for a booster for my 65 where are they in stock please?
The one Rockauto has in stock for a 65 is described as: Front/rear drum; with Field installed Hydro-Vac; with bracket
The one listed without is not in stock.
What is the Field installed Hydro-Vac with bracket?
Trying to determine and locate the brake parts needed to get my 64 Fury going, er, stopping. The car is in VGC, sat a while in storage, but nothing is rotted. Single master cylinder is empty, but no rust inside. I want to replace parts, not upgrade anything at this point, except for a 65 dual mc.
It has power brakes, 4 wheel drum.
My front drums' inside diameter is 10", and the pads are 2.5" wide.
Front wheel cylinder has part #2266368R stamped into it.
According to this, the rear drums and studs can be replaced:
http://hotrodsandhemis.com/TaperedAxleBrakes.html
Studs: BK 641-1128
Brake drum: ND 4401129
Also, according to another member, Dorman studs work as well on the rear: 610-090
https://www.forbbodiesonly.com/mopa...ds-for-62-10-rear-drums.79344/#post-910140206
Will the the drums and studs listed above fit the front as well and allow the conversion?
I'm having a hard time locating parts, even the ones listed above.
When I look up brake parts for a 64 no luck, look up a 65 and they are available.
Cardone booster 54-73456 is available for a 65, will this fit a 64?
What wheel cylinders, brake shoes, and hoses fit?
Between NAPA and Summit, it appears I can get what I need, however I might have to mix and match between 64 and 65, and guess unfortunately.
Just wondering if anyone has gone thru this before.
Rock Auto has all the parts for you brakes. I just used them forr my 64 Dodge Polara build and all is well.
FYI: Ordered a booster for a 65, part #54-73546, does not fit.
Rod is too short, circle on rod too small, and has a square bolt pattern, 64 is rectangular.
