19 69 GTX
- 8:15 PM
- Apr 30, 2016
Well I had just the drivetrain listed for sale but I may be better off selling the whole thing. 65 Coronet originally a 318 car now has a 1966 440 with a factory 64 Max Wedge set up. 518 casting heads, factory cross ram and factory Carter carbs. Has roller rockers, forged pistons and has been balanced. Runs on 93 octane just fine and good power. It was built to specs of a stage 3 Max Wedge build with less compression for pump gas. Engine was built a few years ago at a shop in Cleveland Ohio and was not hardly driven after build. I just put new tires all the way around on it and new front wheels for wider tires. It had skinny front runners and it will come with them but tires are junk. Also just put new 3 inch exhaust from the Headers back to rear axle with dumps. Has four piston ssbc front disc brakes with drilled and slotted rotors stops great. Trans was rebuilt and shift kit installed. Its a on the column cable shift trans. Interior is very nice with seats already done and nice headliner. Needs new carpet its the original carpet. Door panels are original and in good shape. Engine bay has been repainted original color and body is sporting the original paint with cool patina. This car was from Oklahoma so its in great condition bidy wise no filler or rot in body. Does need on spot on passenger floor pan fixed. I have a new pan or cut out bad piece and repair. Rest of floors, trunk , frame is like new. I know if I kept car id want to do a Gen 3 Hemi Swap and it's to cool of a car to do that. Car is 23k firm located in Terre Haute, Indiana title in hand. Can send a video of it running to a cell number.
