66/67 C pillars
YY1
2:54 PM
FL
Feedback: 3 / 0 / 0
Wow Never seen this but Sattelite needs from the factory seam up to about 8 or so inches including the drip rail. Could also use under back windscreen corner.
I know...that's a 68-70 B and E problem, not typically on 66/67.
Finally got a pic.
The area is somewhat smaller than originally thought.
About 6-7 inches up from the seam, and about 1.5 inches down onto the quarter.
If anyone is doing quarters or patches on a 66 or 67 Satellite, Belvedere, or Coronet, and you are either cutting below this seam, or otherwise not using these panel areas, I would certainly appreciate being kept in mind.
I really need both sides.
Looks like we might need the inside area as well.
Thanks.
