66 67 rear seat removal
ernest l hill
New Member
5:59 AM
Circleville
thanks to J-B upholstery Circleville Ohio ! rear seat removal 1st remove nut ,, outer side of seat, this exposes bolt, that bolt will retract into seat it is spring loaded to aid in removal .. 2nd inner side of seat has an adjustable nut ,, run this all the way in to seat ,, you need 5/8ths wrench and thin vice grip , this bolt is not threaded on center counsel side it simply slides in ,, just finished removal 8 /5 2021 its not easy but it is doable just don't wear your self out
Must be convertible. Hardtops have no hardware holding seats in in '67, I'd assume same in '66.
There a couple of bolts holding the seat back in place on my '66. The top of the seat hooks in and the bottom bolts in. Saying that it's not hard to remove. I locked my keys in the trunk a few weeks back. I managed to break into the car, with a piece of plastic cardboard strapping, remove the rear seats, push through the divider, climb in the trunk and retrieve the keys in about 5 mins flat.
This is for a 66-67 Charger with rear buckets seats. Right?
First thing I thought when I read the title ^^^
