66 and 70 - 8 3/4
Monkeymaster
2:50 AM
Iowa
Hello,
I have a 66 charger with a 741 8 3/4, I also have a 8 3/4 out of a 70 charger that has a 489.
I plan on pulling the 741 out, and putting the 489 in its place.
I want to use a clutch type sure grip and plan on 3.73 or 3.55 grear set.
I know the 489 and 741 will swap each other out into either of the rear ends.
My questions are.
What other parts will swap between these two rear ends.
What, if anything, do I need to be aware of with the install of the sure grip, I vaguely remember something about the adjuster and or the axle spacer/button, that goes between the axles?
Is there any advantage of one year over the other, I thought the 66 was 3/4" narrower, so maybe tire selection would be greater , albeit only a little ?
Thanks in advance
The 489 is the cone-type sure grip. All the internals of the center section must be 489 parts, they do not interchange...the carriers themselves are the interchangeable part, though 741s use a smaller diameter pinion & yoke..axle spines are the same...not sure about the overall housing width, that varied by series (A/B/C/E) if you install the green axle bearings you eliminate the endplay adjuster and spacer
..and if you ask these folks which is better, green or tapered bearings just start your post with this...!
:popcorn:
:popcorn:
I don't think its a "which is better" thing, more of a "I'd rather not set end play" thing. I think most know tapered roller is the better of the 2 ! :lol:
the entire sure grip unit will swap between any of the three cases.
gear sets and IIRC bearings are case dependent and do not swap.
