66 coronet coolant overflow
George Warmouth
6:03 PM
Pennsylvania
Hello my 66 coronet with a 1969 440 runs about 190 to 205 on very hot days not all that bad of temps. Just started yesterday to push coolant out the over flow when I turn the car off. What might be causing this. Never did this before. Ordered a coolant recovery tank. The car was done without one.
Could still be the thermostat possible. If it opens properly operating temp would be normal. But if it stays partially open hot water could go back into rad or expansion tank. But I wouldn't think it would happen as soon as u turn car off. Recovery tank would help but also might mask another problem. But if it works it's the way to go
Thank you for the input
Original downflow rad.? Maybe level is too high?
With a recovery tank, you will also need a radiator cap for a sealed system. If not, it will suck air back into the radiator as it cools.
Take your radiator cap to a parts store and have them do a pressure check with a Stant tester. It may just need to be replaced. As was said, the level in the radiator, when cool, needs to be +- 1.5" down to allow for expansion of the coolant when hot.
Coolant recovery is the best way to go as it purges all the air from the system, which reduces corrosion.
Agree with radiator cap problem
Take your radiator cap to a parts store and have them do a pressure check with a Stant tester. It may just to be replaced. As was said, the level in the radiator, when cool, needs to be +- 1.5" down to allow for expansion of the coolant when hot.
Thanks for the info
With a recovery tank fill the radiator to the top and add a little coolant to the tank.
It will only suck air if there is no hose from the cap to the bottom of the tank. With a proper two way cap on the radiator, it will suck coolant back into the radiator when the coolant cools and contracts.
When you shut down, obviously the cooling system does as well, so the engine has no way to dissipate the heat. It's called "after boil". If you have an expansion tank on top of the radiator and don't leave room for expansion, it WILL puke coolant out until it makes enough room for expansion. That then would become your MAX coolant level.
If it had never done this before, I would ask if you just serviced or filled the cooling system (perhaps too much?).
If not, then something has changed and a recovery tank might just be a bandaid.
Thanks for the input
