66 Coronet rear window
66 Cornpicker
5:44 AM
Bedford, Ohio
Where can I buy a new rear window for my 66 Dodge Coronet ? Must it be removed to install new headliner ? Thanks
I have a used one if you are interested.
Certainly a lot easier to put a headliner in with the glass out everywhere, but it can also be done with all the glass in!
Thank you Dadsbee, I didn't know that, I always thought you needed to pull that headliner through the window opening to get it tight and on the teeth to hold it. Thanks
Thank you both, I will try new first to see if they really have any !
Be careful with that. An original will fit. Will an aftermarket? I have an aftermarket brand new rear window for a 69 GTX in my loft because it don't fit. Had to put an original one in. Not sure why I even bothered to keep the piece of junk.
