66 Coronet trunk lid conversion to 67 r/t trim
david bench
1:52 PM
Pittsburgh,Pa
Hello i have a 66 coronet 500 and want to replace the trunk trim panel with the 67 trim and it seems that the filler panel will cover the key hole and suggestion looks like the lid my be different any help out there?
Yep, the sheet metal on the back is totally different and the style lines on the top go "the other way"- center is raised instead of depressed.
Key way is below the trim and you will probably need to change the tailight extensions.
