SOLD 67 barracuda formula S 273 commando
MoparRobTX
1:34 AM
Houston
Feedback: +1 / =0 / -0
$9,900 obo
1967 Plymouth Barracuda Formula S Notchback
Yellow with black bucket seats and console.
Originally a gold metallic car.
I have the IBM card decoded from chrysler historical but no fender tag.
Rebuilt 273 .060 over (less than 50 miles after break in)
Egge 10.5:1 pistons
Summit Double Roller timing chain, Summit Balancer, Summit .454 lift cam (K50052)
302 heads with new valve seals-hydraulic lifters and stamped rockers.
new melling oil pump, new water pump
rebuilt edelbrock carb
Weiand stealth intake
electronic ignition (orange box)
New Accel Super Stock coil
New Summit headers coated with VHT header paint
A904 transmission
8-3/4 axle - not sure of the gears
Front disc brake swap and aluminum master cylinder.
Painless wiring harness
new O'Reilly battery
new battery tray
New throttle cable
New upper control arm bushings
New upper and lower ball joints
New inner and outer tie rods
New pitman arm
New idler arm
New sway bar end links
New steering coupler
New front rotors and pads
rebuilt rear wheel cylinders
New U-joint
New rear brake lines
New Jegs 2.5" dual exhaust (have not trimmed the tail pipes yet)
New horn contact ring and turn signal switch
New carpet
New rear seat cover
New package tray
New wipers
New front cooper cobra tires
