WTB 67' Belvedere Strut Rod Washers x4 spacers x2
Auggie56
2:53 PM
NW Ohio
Feedback: 4 / 0 / 0
Need four strut rod washers and two spacers.
I have two washers from a 68 B Body (1st pic) if they're the same as '67. My guess is that they are. I have a sandblaster at work so I can blast these to see if they are pitted or not. I have two washers sandblasted from a '73 B Body (2nd pic). They have the same diameter, same hole diameter and same thickness. The difference is they have a stepped cup where the 68s have a continuous curved cup.
Also, what are you referring to as spacers?
Thanks
The spacer is a metal tube that goes over the strut and once the bumpers are installed they butt up against the washers so as not to crush the bumpers.
I found several kits that have that spacer included just no washers. Shoot me a price as far as blasting the two I have the means to clean them up.
Thanks
Is this the spacer? Measures 2-13/16" long, 3/4" diameter and approx 1/16" thick walls.
If so I have two of them.
I have what you need. I just pulled it from my 67 satellite.
