67 charger lighting issue
lordofrc
6:13 PM
Long Beach
I am having an issue with all of the lighting in the car. The headlights hi and low, parking lights, guage lights, tail and brake and license plate lights, and turn signals, none of which turn on. The headlights do however rotate into place and return. I cant understand what it could be if the headlights will rotate but not actually illuminate. Any ideas? i have manually tested the light switch, and the hi and low switch and checked all the bulbs just in case.
Make sure that you have good ground connections. Start by making sure that there is a good ground from the negative battery connection to the radiator support. When mine got dirty I lost the headlights. Also make sure that you have a good ground from the back of the engine to the firewall. Good luck!
i got the head lights (hi and low), turn signals, and flashers to work but the parking lights, tail lights and stop lights still do not work. I think it could be the headlight switch but ive tested three or four extras that i have and i still have the problem. I dont think its likely that three headlight switchs all have the same problem. Any more ideas would be great.
