67 gtx
sparkykd
3:18 AM
indiana
I need some help with ID number locations on a 67 GTX. I know there is a VIN on the drivers door jamb, ID tag screwed to motor compartment tire well, would there be stamps on the body side trunk lip.? Is there any other locations? Car had no motor or id tag in motor area but has a good tag in the door jamb. No build sheet. Looking for other varification on car.
On the trunk lip under the trunk seal on the drivers side.Also on the drivers side radiator core support, sometimes you have to pull the top of the radiator loose to see it.
67 has no numbers on the trunk lip. You have a SO number on the core support and on the rear frame just inside the driver's rear bumper bracket.
