67 R/T build date
I would think so. I registered my R/T on the 67 R/T Registry Facebook Group. They have all that info, and I found out mine was made in Dec of 1966. I looked and saw the earliest ones on the registry started in Sept of 66. You may want to register your car on there, it is interesting to read.
https://www.facebook.com/groups/158376571459313/about
That is a pretty early build date. Your car must have a very low serial number.
ok , so my 67 coronet R?T has a build date of 9/28 . i am assuming that is 9/28/66 ?
If that date is from the fender tag, that is the SCHEDULED build date. It's likely not the actual date of assembly. The car could have been built a week before that date or five weeks after. It's impossible to know for sure.
That is most likely the case! Unless you have a really high serial number, then perhaps it would be 9/28/67? But that would really surprise me.
Construction of the '67 models would have ended in July of 67. Construction of the 68 models would have started in late July/Early August of 67.
My '67 R/T was built in November, 1966. Serial number starts 143xxx, so is later than yours.
