Hey Dave, hope they get ig right. How did she run?
Thanks for asking. She ran good but man those mopars start hard after sitting a while. Rebuilt the carb but have to pump the crap out of it before she settled in ( had to do this before I built it ). Had to mix in my zinc additive.
Your choke all hook up and working Dave? Id start there if your pumping it that much to get her going.. Tighten down carb bolts, maybe loose? Just a couple suggestions..... Good luck.
I have to pump mine like 6 times before i start it, if it has been sitting a week. It fires right up and runs good. I guess the gas just evaporates from the carb. Electric fuel pump may fix it.
Dave
	Thanks Ron73 I will check the bolts ( choke is all hooked up and fully closed when starting up ). I had this problem before I built the carb thinking it was drying up in the bowl but when I hit the gas it squirts right away. Have to pump about 10 times before she fires. I know she wants gas because If I dont pump her she wont start. I should probably just put a electronic fuel pump in.
Dave
Here is a couple of pictures of the planes. Haven't flown much this winter, windy and rainy. Ask anything you like, I tell you what i know.
DF
