69 383hp
jhite
12:43 AM
patriot IN
I am looking for a somewhat complet 69 383hp engine to rebuild for my RR its build date is 6-18-69 so something close to that would be good but what do you have
383
i have one, standard bore, never touched other than dissasembly
i have a few set of heads, matching crank, push rods,rods/bearings/caps/ rockers, oil pan,
just about all there , are you going too build the snots out of it or pretty much keep it too factory specs? also ,you want a 68 cast date or a 69 cast date?
69 383
Let me take a look, got two 383.
If these guys don't have what you need let me know. I have a 69 383HP block had been checked at a machine shop sitting inside for years
Got a 4-4-68 long block if this helps.
I have a mid Feb 69 383 HP BLOCK ONLY out of runner or bee - don't remember - that I could part with. I may have a set of 906 heads and a crank. To bad I am in CA, but it is available.
