69 bee
Copper bee
New Member
3:00 AM
Denton Tx
I installed the hotchkins fast ratio pitman and idler arms on my 69 bee and the idler arm hits the torsion bar has anyone else had this problem before
welcome to FBBO
I do not like that method of steering ratio change, modifying a parts length or angle. Its more expensive, but I prefer changing the gear box. Borgeson makes a great setup. You might send the Hotchkis parts back and try the PST parts, they're a lot less than Hotchkis. If they don't work, try the Borgeson box.
Got any pics of that copper Bee?
Never fear.
Someone here will steer you in the right direction.
Welcome to the site. I would contact Hotchkis to ask about your problem and how to fix it?
Yeah, those items change the geometry a bit.If you want a easy fix.They make grease fitting plugs that screw in that would clear. I have used them before with header clearance problems.Grease 'um up then replace the fitting.Just a thought.
