69 charger door lock mechanism location
vabchmopar
11:01 PM
arizona
I can not figure out how to install the below door lock mechanism for the inside door locks. Does anyone have a picture of one installed. Thanks for any help I can get, out of my 69 charger
That rod with the 90 bend goes into a plastic clip ,on the mechanism, then forward to the swivel which bolts to the inside frame , but put the machined end ,for the pull knob , up through the lock rod hole first & bolt it in place.
Also those are side specific ,& all you can really see is the head of the bolt.
I can't see where it bolts to the door frame. I have tried all the holes in the door but just doesn't seem to fit. I know the treaded end is for the pull lock, but where on the door does the assembly attach. I don't have the window tracks in is that maybe my problem/
I see on another tread that a 68 coronet the lock rod goes straight down from the knob to the door latch, the 6 charger is different as it has a swivel joint in it. Where that swivel bolts to the door is
whooping u on me, see picture above)
