69 Charger trunk floor
Jon Erickson
3:34 PM
CT, USA
I have a 69 Charger that needs a trunk floor like most do. I also have to do the quarter panels on it. My question is can I slide a 1 peace trunk floor in through the quarter panel area when removed . Or do I have to take the tail light panel out to slide the one piece floor in.
As I recall the answer is no. Unless one inner wheel housing and upper deck lid/dutchman panel support braces are removed.
If you are replacing the rear valance you will be able to slide a full panel in under the tail light panel. Otherwise no
Sounds good about the valance direction. I do have to replace that also thank you for the information.
Jon
