69 GTX column shift to floor shift?
MrDee
6:51 AM
Wisconsin
I'm thinking about changing my column shift to a floor shift with a console. Besides opening a hole in the floor, what will I need for a factory swap?
Besides the hole in the floor, you'll need the hump that fits over the hole,
the shifter to bolt onto the console, shifter linkage, floor shift style torque shaft, and if you want to get rid of the steering column shift collar you can get a floor shift version.
The console itself will require additional brackets welded to the tunnel.
This is an automatic transmission, not a 4 speed swap. Sorry, I assumed switching from a column shift would be enough to say this an automatic. We're there 4 speed column shifters in a GTX?
And you think I can just change the collar on the steering column to get rid of the shift indicator and lever?
Tony's Parts came out with that collar a while back to make that possible. My former Hemi GTX was a column to floor conversion car. The previous owner who did the work changed out the entire steering column to get rid of the shift indicator and lever. Note that he used a console from 1969. Probably got a good deal on it, and he wasn't worried about originality.
Now that would be neat- a GTX with a 3 on the tree!
Until the 440 smashed it to pieces
Wow, I’ve never seen a GTX without buckets and consol. Kim
In 1970, they were available with a bench, production around 50 units, if I recall correctly. I had one with a column automatic in the late 70s. I owned a buddy seat, column automatic in the 90s. Both cars were hard to sell when the time came, even though they were nice, heavily optioned examples.
