ykf7b0
I have installed another temperature gauge and still no movement. I am getting pulsating power via test light at the multi-pin connector on the circuit board with the violet wire making contact. This tells me the circuit is moving through the board and the gauge. I have yet again pulsating power at the sending unit connector plug. I don't think I could have two bad temp gauges especially when both are said to be functional. Do the senders in the water pump housings generally go bad? I'm going to install a new one and see what happens. Is there anything I am missing regarding this? What's left?
