WTB 70 B-body 3-Speed Wiper Switch
Rallye dash or standard dash as they are different. I believe I have a standard dash 3 speed switch. Pm if needed
I think just the chrome rocker is different - switches themselves are the same. The plastic rocker can be removed and swapped. Also., 68-70 would use the same switch.
one version is smooth chrome, another version looks like a sandblasted or satin finish. Good chrome is hard to find and mine won’t have good chrome. I actually modified my two-speed chrome rocker to fit my own three-speed switch.
I have a couple extra switches and also have the resistors - which are commonly broken or missing
So now, it's all about the condition of the plastic chromed switch.
I have several 3 spd switches. I was unaware of the difference in rocker switch plastic. Any pictures?
To help the OP it's a satin finish rocker. This is a 2 speed standard dash switch but the rocker is the same as a 3 speed std dash and I believe it's narrower that the chrome one... Rally dash chromed rocker 3 speed switch for reference to show the different rockers but the switch itself IS what you need.
The "chrome" rocker is used on the standard 68/69 Plymouth B-bodies for sure. The rocker is NOT interchangeable between the two and three speed switches without some modification.
View attachment 1633551View attachment 1633552
Good explanation. Thanks.
If you have a chrome rocker, a c body nos switch can be modified into a b body rocker for a fraction of the price.
He is looking for a 70 standard dash 3 speed satin rocker switch NOT A 68-70 CHROME Rocker switch… @devinism can probably help the OP.
I am less concerned about this finish on the switch, a little steel wool will bring the chrome finish down. If it fits in the slot, I’m good.
Go back to post #11. I believe they are narrower than the chrome one. The member I posted could tell you more as he deals in switches and rebuilds them. Hopefully he chimes in.
The more I read, the less remember.
All my standard dash switches are chrome. The rallye dash I have that's apart, appears to have the same width switch. I was unaware of a satin switch on a rallye dash, (see screenshot) and have only seen the narrow satin switch on C body.
A quick look found a good switch with bad chrome, the switch with perfect chrome has a bad resistor, and I have a couple in dash clusters yet to be pulled.
I have many 2 speed with good chrome toggles to swap.
I PM’d you. Let me know what you want for the one with the bad resistor ( in PM) please.
