Texas97
i have a recent problem, car won't start. i ran it in a parade, middle of parade, i get a washer fall out of either the column or somewhere around it between my feet. ok, that's weird.
i park after the parade, no start when i come back out. first time this ever happened. jump across the solenoid, cranks and runs fine. i replaced the solenoid, same no start issue. i think its wiring in the column, related to the ignition switch. has to be related to the lost washer can't be coincidence
do i need to pull the steering wheel and everything to get down to it? and other way to go about it?
also my turn signal return cams must be broken, because it won't turn off when i complete the turn.
