70 coronet
Got these fabbed up...driverside is rock solid,pass is not rusted thru but THIN in spots ...I just made both to be...symmetrical ... the mustang hood leftover came in handy...AGAIN...:lowdown:
Finished fabbing up latch patch... Do NOT attept this without a bolt n nut attached...keeps the patch from dropping dow between the latch panel and the reenforcement strut..ask me how I know...12" steel rule with aluminum body tape saved the day...UGH! :lowdown:
Got the window channels fine tuned and steel mesh behind the rust hole for body man in a can removal & leading after I get the welding all done....just waiting to hear back from the welder ...:jackoff:
Trunk Valley Pan prep ..used the ol V.P as a templete and cut the new one oversize ...for UNFORSEEN hurdles. Trim to fit ideology n better to have too much rather than not enough...I'm melancholy on the replacement floor pan fitmit...the 2 1/2's obviously were stamped on 2 seperate presses n dies.... :wtf:
Used WEAK fridge magnet to check for bondo around rear window, GLAD I did found a lil more right under a spot I'd already addressed. Magnet stayed put on the rest..
Fingers CROSSED weld n sheet metal guy is coming on 05-31...then I can get to lead'n the 2 spots by the rear window :blah:
