A-12.F6
71 440 HP block, cast 2-11-71, top pad reads G 440 4 5 HP A.( A=.020 over bore from factory), will need another .010 to clean up bore, steel crank, six pack rods and damper, 71 HP distributor, 187 oil pan, 346 heads.
Crank and rods have been magnafluxed and are crack free, crank will need to be turned .010 to clean up surface rust on journals.
local pick up in west central MN $650.00.
