bee71
Still looking for help on my A/C vacuum lines. My car has an electric motor for my headlight doors,but there is a vacuum can underneath the battery tray. There is a vacuum line running from the manifold tee along the firewall and along the drivers side front wheel well. It then has a black factory nipple connector connected to another vacuum line that then runs back to the firewall and down to the grommet that goes through to the A/C heater box.Was the vacuum can one of those items that is put on by the factory if the headlight doors were to be vacuum operated? Or is it supposed to be working for the A/C controls? I need anyone that may have the same untouched factory A/C setup to help in finding out if I should have these lines connected to the can. I have a 4speed with manual drum brakes. My system seems to work,however it will not switch from A/C to Max A/C. Thanks.
