Dibbons
- 5:38 AM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
I used to set my small block bracket racer with 35 degrees total timing (with vacuum advance disconnected). Now I wonder where to set the timing when first starting a re-build which would be a 2,000 - 3,000 rpm fast idle? And would that be set with or without distributor vacuum advance hose connected? Thank you.
