71 charger brake line size
Mikey59
9:09 AM
Cottage hills Illinois
Just ran brake lines from rear to prop. Valve. But wanting to install a line lock. In-between the master cyclinder and the prop. Valve but not sure what size it is does anyone know size it is? It looks like is 1/8". Coming out of the prop. Valve to the rear is 3/16.
Line ID doesn't matter. It's desired
pressure and flow. The 1/8" line
should work fine if your system
pressure is adequate.
iam going with all 3/16 line. Going with a new master cyclinder and making up my lines just takes a little bite of time.
