Anyone know anything about the hidden headlamps on a 71 charger? My charger had the original hidden headlamps replaced with a standard grille. After finding the original grill, doors, electrical, and motor, today I test fired the system. The problem im running into is when the doors are opened or closed, the motor is wanting to turn to far and is tripping the circuit breaker in both directions. If I unhook the torsion rod from the doors the motor actuates perfectly in both directions. The torsion rod seems to get a bit of a twist to it when either closed or opened, and im sure its to keep the doors from rattling or bouncing, but when hooked up the doors it tries to go to far. The doors were disassembled cleaned and greased and work very easily by hand.
