71 sat need some help
mopar_buddie
7:36 PM
Lubbock
hey everyone i just purchased a 71 satellite, no engine no trans id like to do a 383 with a 727. this is my first resto project so... sorry for the stupid questions. now im looking to save cash so im going to try to put it in and get it running my self my first question is will the engine bolt right up or will i have to get motor mounts is there a difference in the mounts from a sat to a RR
mounts required unless it was a satty sebring big block.. I've seen em with 383's before if i'm not mistaken
If the car had a small block (318,340,360) from the factory then the 383 will not fit, you will need a big block K-frame from another 66-72 B-body such as: (Satellite/Sebring/plus,Roadrunner,GTX,Charger) or you can buy shumacher mounts to make it work...If the car came with a big block(383-400-440) then your fine :)
B-body K-frames from 73-74 will not work in your car!!
This is the link to Schumacher:
http://www.engine-swaps.com/
Oh if you use the Schumacher mounts you will have to use a center sump oil pan to help clear the K-frame.
That's not correct the 71/72 v8 k frames are the same for big vs. small only hemi and /6 had different k's. We are not tied to the same rules as the 73/74 3rd and a half gens.
You do nee the big block motor mounts though. Very easy to get from mopar or mancini.
The real issue is your wiring, cooling, and rear end. It's not insurmountable though.
That's not quite true.
the 71/72 v8 k frame is the same for BB or SB. In 73 they started doing the different K members. He just needs the BB mounts. If it is sb car it will bolt right in. If its /6 then yes a different v8 member is needed.
The more difficult issue will be wiring, linkage, cooling, and whether the rear can handle it.
Welcome, I have nothing to ad that the guys before me didn't allready say, accept lets see some car ****!!
Aww crap! Sorry guy's, I had a Brain Fart!! :)
