72 brake problem
grainman46
New Member
11:43 AM
titusville,pa
have a 72 r/r that brakes pulled bad left found r/f caliper binding replaced caliper and brake hose still pulls left braking not quite as bad but still need to pay attention when braking help
Check the opposite side ... also adjust up the rear brakes properly. If you haven’t, have some one work the brakes while you rotate the tires and check for apply and release ...
replace calipers and hoses in pairs
shoes and wheel cylinders in pairs
half a job will cost you
