What's the better Spicer 7290 joint, the solid 5-811X or the greaseable 5-1309Y? I don't think either are solid.
Can you elaborateYou realize there is a right way and wrong way to install a greasable u-joint - right ???
You want the grease fitting in "compression" not "tension".
lol. what? thats what happened to it after it failed lolWhat happened to the yoke? It is spread apart where the u bolt goes through.
If yoke doesn't support the u-joint then any u-joint will fail.
Thanks. Pretty clean diagram too. Makes sense.See below. Under power the driveshaft is "compressing" the grease port - which is the weak point. This is acceptable. However if installed such that the the grease port is in "tension", the chances of breakage a significantly higher - virtually guaranteed with a combination of power and traction !!
