Do you mean the front frame rails? Or K frame? I have the complete front frame rails from a 1973 B Body including the torsion bar cross member. Absolutely rust free.
I have a 1974 BB Kframe which needs a little work on the rear mounts. (I was reconditioning this as a project and its still in the works but willing to sell) It has the upper and lower control arms with brand new never run bushings and ball joints. A good used idler as well as good used strut bushings. Also have an excellent torsion bar cross member.
I'm going to be cutting out the rot and replacing the metal. My plan was have solid aluminum or steel pucks for solid mounting to the frame rails thus eliminating the stupid rubber ISO crap that contributed to the rotting in the first place.
I'll take some pix of what I have showing current condition tonight or tomorrow if I have a chance
Ok that would awesome I called up a local fabricating place and they said they could probably do it but it'll probably be be veery expensive I'm thinking
Here is what I have.
As I mentioned the rear legs need work and they had been replaced previously it appears.
The lower control arms aren't finished as I have only pressed the new bushings on the pins and not yet into the control arms themselves yet.
