73 rear sway bar bushings
redrr
6:21 PM
new york
Anyone have a way to change the rear sway bar bushings on my 73 roadrunner? Break the weld and weld??
Here are some pictures
Slide it off the bar, remove the bushing, install the new one and slide it back on the bar. Lots of lube helps.
If your not going for factory original look drill out the welds & then bolt back together using lock nuts or similar.
