'73 Roadrunner dashboard.....
rgp266
1:17 AM
East Lansing, Michigan
Can the complete dashboard be removed without having to remove the windshield first? Just got it torn down enough to get the padded dash out of there for restoration and seem to be pretty close to just pulling it the rest of the way.
Somebody please shoot me in my head if I ever unzip one of these things again.
Thanks.....
Bob
I removed the metal dashboard and frame on my 73 RR etc without removing the glass - its a little tight but can be done. Remember to drop the steering column and other things in the way.
I have photos while removing and reinstalling - just email me at ralphcali@yahoo.com and I will send them to you
Ralph
Ralph
RALPH , i would like the photos so i can reference them along with mine just in case i missed some stuff in my pics when i goto put my rr back togather .
can i email you my email also please .
thanks RANDY
No you will not have to take out the glass, BUT that will be about the only dadgum thing that does not have to come out. A month or two back I did a dash pad and all plastic restore ,
If you need a breakdown emailme
Rav440, send me your email I will send your some of the photos.
thanks Ralph
Very easy to take the whole unit out...the whole thing can take less than 30min to do.
I'm doing this from a 10+ year memory so forgive me if I leave out a couple of details.
Unscrew the few screws holding the A-pillars in, and remove them.
You'll need to remove the 3 bolts from the underside of the dash that supports the column. You'll also be smart to loosen the three bolts that retain the base-plate where the column goes through firewall. Drop the steering column down as far as it'll go. You can also remove the steering wheel to allow it to drop lower, but not needed.
Also take this time to remove the speedo cable and the wiring from the dash to steering column. Unplug the main dash harness from the bulkhead on the firewall.
The following works much faster when you have two people.
There are a couple of screws/bolts along the base of the windshield (helps to have a flex-driver to get to them), then, remove the two kick panels, and loosen the two large bolts that anchor the dash frame to the lower A-pillar. Just back these off a couple of turns, DO NOT take them out.
You'll be able to tilt the entire dash frame down towards the front seat. If you have someone to help, have them support the dash as low as possible, while you reach behind the dash assembly and finish unhooking and unplugging anything that connects the dash to the car.
In a short time, you and your helper can lift the dash off the two A-pillar bolts and remove the dash from the car.
I've done this a lot at junkyards, it takes a short time and very basic tools to do.
