Sat66
Need a little help. I switched from a 741 open center section to a 489 cone type sure grip in my 66sat. Now during the dry fit the axles won't go in all the way. (About 1/2"or so is still sticking out). Before I took the 489 in, I took the drivers side axle and slid it in the 489 when it was on the bench to make sure the splines lined up. I took a tape measure, slid it in until it bottomed out, 26 3/4" and the axle was a little shy of that. So it should be good. I know the splines line up because I can turn the axle and the yoke spins. Am I missing something?
