SOLD 8 3/4 742 case pinion spacer sleeve
The 742 doesn't use a crush sleeve....but uses a spacer. I'll take a look....should have one.
Edit...yup, I have one. PM me.
The 742 does not use a solid pinion spacer or crush sleeve. A 741 uses a solid pinion spacer and a 489 case uses a crush sleeve. The 742 needs nothing due to the design of the pinion.
Do you know the thickness of the shim you need? There's several different ones. I have a few, might have what you need.
Thanks for learning me.Would bet Mancini has those too.
Been awhile since setting up any diff....it's nuts what ya forget over time.
