8 3/4 Yoke
Brew61
5:24 PM
Penticton BC
I have a 8 3/4 with 7260 universal with straps. I guess someone broke one of the bolts off and instead of drilling it out they decided to weld the one end of the strap onto the yoke. So I am wondering instead of replacing the yoke , has anyone ever drilled out all four holes and replaced the straps with U-bolts?
Bruce
Bruce
Drilled out the threads and used a girdle.....but don't use ones made from aluminum.
Bruce
Are you thinking of drilling out the four bolt holes in the yoke when still in the car ? Can't imagine that would be an easy task. Not much room, how do do make sure it's square ? Plus you will need to grind off the welded strap. I think I would be tempted to remove and replace the yoke.
There is enough room under there. Drilling out the existing holes would be easy, your just running a bit in the original holes and enlarging them. As for the the broken bolt one ya probably better to remove the yoke and put it in my drill press. Just figure it would be cheaper then spending $150 or more for a new one.
Bruce
I'd drill out the holes and use u-bolts, just make sure you get good quality grade 8 u-bolts that fit tight since you don't want any slop in there.
Is there enough flat surface on the rear side for nuts?
