FOUND 8.75 3:23 Ring and Pinion
khryslerkid
2:54 PM
Hanover, Pennslyvania
Feedback: +20 / =0 / -0
Looking for a NEW 3:23 ring and pinion (10 spline) for the 742 case. (Pre 1969)
I'm not interested in a used set. I know who has new sets. I'm just asking if someone might have a New set that they have decided not to use and would be willing to sell.
Why not consider a whole 742 with original gears that someone removed. Might pick up a non- SG cheap?
That's what I did in the beginning. Seller didn't disclose the dozen ring gear teeth that were rusted. They cleaned up but were still pitted slightly. Well I can hear that section every time they come around. Also the pinion creates a harmonic sound through the car at a certain speed. Probably pitted bearing and races.
Anyway I'm not going used. Getting them set right back to where they were originally seated can be a hit or miss. I should have rebuilt this unit before I installed it. Thanks Fran
Update:
Ordered a set from Dr. Diff. Spent the extra for the Nitro gear. $65 more than the Motive. He stated that they are the only two outfits making 3:23 ratio. He also stated the Nitro will be easier to set up than the Motive. Motive has a rougher finish to them and are harder to read the pattern.
Thanks for your replies :thumbsup:
