2 yrs ago I was replacing rear brakes and found my right side axle had some vertical movement aprox 1/8 of a inch with the drum off.
axle end play was to loose also but no leaks or noise.
So I took the safe route pulled both axles and had new oem style tapered bearings pressed on.
I installed new seals and flange gaskets, packed the new bearings with wheel bearing grease with a gun and needle tip , button / spacer was / is still in the sure grip. I stuck the left side in axle was lubed to keep the seal safe, dead blow seated the left side and tightend it up. Backed off the adjuster on right side and installed it the same way dead blow hammer wack put bolts in and set the end play at .010 ,
had to back off one notch to get the keeper in a slot.
Now 2 yrs later I am checking rear brakes & pull the drums my vertical movement is back on the right side aprox 1/8 mabey a touch more , checked the end play its right at .018 on the dial, no leaks or noise.
Is this vertical movement common after run in / breakin on the bearings or am I missing something and need to repack and reset everything again ?
