a couple questions(dust caps and shocks)
jcskokos
11:52 PM
626, California
I need to know what the correct dust cap for the front wheel bearing is on a 67 Coronet 500 4-door. I did my brakes (drum) last week and I guess the old one was pretty worn and I seem to have lost it somewhere in the last 60 miles.
Next, I have been looking to upgrade some of my old saggy suspension, and have come across this:
http://www.summitracing.com/parts/mon-58577st
They look like a nice replacement for the stock struts on the rear, and I have heard of the brand before. Has anyone tried these out and have some feedback?
A coil over design for a shock could quite possibly raise living havoc with your shock crossmember; as in crack or rip it apart. As far as fixing that saggy suspension, personally I would fix the problem with your worn leaf springs, instead of tossing a band-aid on it and making the car even more unstable in the rear. Your money.....your car.....Good luck what ever route you go.
I agree with Propwash, my leaf spring was like a rusty steel spring bed from WW2 and I got myself a pair of new HD from http://marketplaceadvisor.channeladvisor.com/storefrontprofiles/DeluxeSFItemDetail.aspx?sid=1&sfid=92390&c=0&i=10356079
Suspension feels like new, never had an american car before with this smooth feeling, no squiking or rattling, just a firm progressive feeling, I also have new bushings and new KYB.
Or you can have your old ones restored, it is not an option i Sweden but I have read about it in this forum.
So they are just too firm/stiff for the location?
I also take it you recommend the OE stiffness ones, or would it be worth it to throw $10 more for the heavy duty competition spec?
Still on the note of suspension, how about Polyurethane? One of the instructors at Kia headquarters has a couple old Mopars and he swears by it, but one guy at work said it tweaked the frame on his old Ford.
ya,shock crossmember not designed to take that kind of presure.polyurethane will work good if looking to stiffen the suspention a bit.they can be noisey,but most people get used to it or lube them regularly.never heard of them tweeking any frame or body parts,not even sure how that would be possible.
Please don´t compare old fords with our quality cars!
I have HD springs and standard gas shocks, don´t buy to stiff shocks compared to the springs stiffness, you will ruin the mounting brackets over time.
Do you have a front swaybar?
Summit Racing has Mopar Performance leaf springs for $104.88 each P/N DCC-4452982 (LH) and DCC-4452983 (rh). These are OE specs and will bolt right in. They would make a world of difference in your cars ride and stance.
Rockauto (www.rockauto.com) has your dust caps for $1.10 each DORMAN Part # 618100
