A/FX Torsion Bars
Southernman
2:52 PM
Raleigh, NC
Guys, I've contacted Firm Feel to find out if they still make he AFX torsion bars for our early B-body cars and it turns out they do.
The question I have for others is:
The single price is $500.00 and it takes about 6-8 weeks to receive them.
If we were to place a 'bulk' order, we may be able to get a discount on them.
Is anyone else on here interested in purchasing a pair of 10-over torsion bars for a future AFX project ?
If yes, let me know and I will follow up with FF.
Southernman
So I am assuming the A/FX bars are longer since the k frame is moved forward, right? Rodney and I have a 65 Belvedere we're thinkin about turning into an A/FXer. I'll see if he might be interested. I guess it would all depend on how big a discount is offered.
I'd be interested in a pair,If the price is right! How many prs.are needed to get a good price?
Didn't Chrysler use C-body bars in the A/FX cars?
I have a set 51" long hex cut to fit b body if some needs pm me
NO ! Chrysler did not simply use C-body bars in their AF/X cars. As someone who has actually experimented - and built - an AFX conversion, I can tell you Chrysler used a custom (one off) 10 - over set of bars. They DID NOT require you to remove/modify the receiver tubes from the cross member. and that's what you will be required to do to accommodate the C-body torsion bars. Ask me know I know...
With that said, if you're doing an AFX conversion - the C-body bars will result in MAJOR cutting and welding of the torsion bar receiver tubes and cross-member of your car to make them work - and they will require additional, major, reinforcing, due to them being pushed forward (since the C-body bars are shorter than the AFX bars) - leaving just enough room in the cross-member to weld them back in.
If you want to build an AFX car, I recommend getting the correct bars. Otherwise, using C-body bars will result in major surgery and bracing in order to make them work.
Southernman
yep
but, but,I am sure of it, a friend told me his 25 year old buddy knew all about that. He said he read it on a blog. It has to be true.
This is a good thread for all my A/FX customers. I build all the fiberglass A/FX parts for the 65 Coronet and the 65 Belvedere, including fenders, scoop and dash board. Of course I do all the other parts for these cars too. A customer contacted me and I think he is serious about going the 65 Dart Awb route. As of today, 1/25/2013, I have a set of awb Coronet fenders in stock, and ready to ship. Sled City Fiberglass
Guys, as noted in my first post, FirmFeel makes the 10"over (as in 10" longer than B-BODY cars) bars that will allow for "slip in" installation if any of you are wanting to do an altered wheelbase car. I've done a couple conversions with C-body bars - before FF offered their correct AFX bars. They are $500 a pair new. Less if there's a bulk order of 10 or more sets.
On using C-body bars, since they are only 6" longer than B-body bars, they will NOT simply slip in and they WILL require you to cut the receiver tubes out of the cross member to make up for them being 4" shorter than a true AFX bar. It's major work, and you'd better be damned good at fab and welding.
A-body bars measure 35.8" OAL
B-body bars measure 41" OAL
C-body bars measure 46" OAL
AFX bars measured 51" OAL (If you're even thinking about such a conversion - $500 is a cheap option versus the C-body bars).
Southernman
i took a set of bars from a 68 c-body they are 51'' had to take off 0.030 off the hex but they are long enough though
I wish assumed experts would research or tell all when making statements of fact. What is losely called out as a 'useage' of the C body bar in an AFX really would have been a D body, ie Imperial bar at 50". So a wrong direction in term gets bad info spelled out as being 'too short', with out actually telling a fairly correct idea that a 'full sized' car bar will 'work'.
I am agnostic on what bar is ideal, just how half correct info gets spread around.
Wow, so we're being taken to "school" here by someone who is an expert on..."D" body cars. Dude, your expertise is truly inspirational...even though it's a bunch of BS.
Here's a pic of a recent AFX built by me, using C-body Imperial bars, since the "ever elusive" D-body Imperial bars you dream of were not available during my build. Perhaps you could pull a set of those D-body Imperial bars and load up some pics with a tape measure behind them - OR, even better, how about some pics of that build of yours ?
Here's mine. Now let's see yours...
HI take a look at afxer .com build pic. of my awb plymouth using 51" bars that needed to cut down to fit the hex ends. and if you are doing a 1510 car you do have to lower the point where the torsion bar connect to cross member "it need to be lowered. All the factory car were that way. This car has a k frame an controll arms. You can see how low the torsion bars are.
View attachment 102352The early Imperial bars were used on my AWB The chassis shop that did the chassis didn't have to lower the k-member! It is the full 15" on the front.and 10" in the rear! This is a pic. of it .I don't have a pic. of the k-member and bars!
I have a dumb question for southernman! No offence intended but why did you move the frt. wheels forward and not the rear? Or haven't you gotten that far in the project.I'm just curious is all.
No offense taken, and I think you have a cool car there. I'm just not a "true" AFX fan (no offense). More on that below.
The 51" bars are correct for an AFX build and have the correct spring rate, hex dimensions, etc, but I didn't have a set, so the C-body Imperial bars, which are 5" shorter then TRUE AFX bars (with much larger/stiffer bar dia's) were used - and I understand that others have used them as well. However, the 51" bars do not require receiver tube/cross-member modifications, whereas the shorter C-body Imperial bars require cutting down the hex to fit the B-body receivers, and the receivers must be removed from the cross member; cleaned up; relocated 5" forward; re-welding; and considerable bracing added. Or, you can simply custom build your own cross-member and drop the bars to replicate the AFX stuff. Either way, it's a lot of work.
Again, it's a good/fair question. I didn't move the rears because I was shooting for a "stretched" dragster look, and I was not really interested in replicating the AFX setup using a station wagon. In truth, I (personally) don't like the look of the AFX'ers with rear wheels moved up and their nose-high stance, though I love that era of cars. I like any car that has the front wheels pushed forward netting a positive weight bias with engine setback - and a slight nose-down stance. It just scream "dragster" to me...
For that reason, I simply moved the K-member; shock towers; all sheet metal; firewall pushed back and flat; suspension; and receiver tubes to move the wheels fwd 10" - while maintaining the clean rake of a late model pro-street car. The 10-71 blown Hemi is just icing on the cake. One other thing of importance: At 10", half of the K-member modifications are "solved" using existing holes, leaving only the other 2 hard mounts to be installed. It requires opening up the frame; welding; and sealing it back up. Those of you who've done the mods know what I'm talking about - and it's also the reason Chrysler Engineers settled on 10"...
And, Steve, I never said I moved my cross-member: I stated the receiver tubes have to be flipped with a C-body bar and rewelded - unless you choose to drop and custom build a crossmember.
So, in summary, I modified the front suspension to achieve the "look" I wanted. That's all. Thanks for asking.
Southernman
PS
Listen, here's another bit of trivia for those out there who still seem confused about bars:
If the stock B-body torsion bars are 41" and you move the suspension forward 10", a true AFX 51" bar fits perfectly - with NO modification "required" to the rear cross-member - and the ONLY company out there that makes 'em is FirmFeel @ $500/set.
If the C-body cars came with a 46" bar SIGNIFICANT MODS WILL BE REQUIRED to fit them to the B-body cars, and the spring rate will not be the same as the AFX'ers. Stiffer bars, worked for me given the weight of blower, hemi, etc...
Rule changes impacting "through the hood" engine setups in the 60's resulted in racers spacing the K-members down to keep their engine combinations compliant, which is also the reason torsion bars were spaced down. This was due to Ramchargers showing up with roots blowers and destroying the competition with such set ups. Hence the rule change. This also affected NA setups using crossrams etc, and the Dart SS is another setup caught up in these rules. A true Dart SS will have the K-member spaced down to meet the "under the hood" rule changes of the day.
There is NO requirement to do such mods on a street driven altered, and you CAN tuck everything up under the car to arrive at the nose-down, low, rake of a modern day pro-street car.
