I'm about to pull my hair out, I've been fighting the timing on my Charger for far to long. I started out with a mechanical adv that worked well for a while then started breaking up when mashing it (hard acceleration). The timing was set at 16 btc initial (it actually liked allot more initial than that but was hard to start) and 36 btc all in at 2,400. Since I mostly cruise with it I decided to try a Mopar vac adv, I can't pull it below 20 btc without it dying now so with it at 20 it runs decent but still stumbles when downshifting and mashing it. Set the initial at 30 and it idles better, pulls better vac (16), has better throttle response, pulls flawlessly threw the whole rpm range but has a miss while cruising (2,100-2,500). I checked the timing mark while I was degreeing the cam so I know it's right and it was set with the vac disconnected. Is there a reason this thing wants so much timing? I haven't had anyone around to help me check the advance so until then I don't know what rpm it's pulling it in at. From what I've done it seams as if it's coming all in a little to early causing the cruising speed miss since it doesn't do it with the initial set at 20 and does at 30. My distributor (383-400) doesn't have the adjustable vac but I have 3 440 ones that do, are they (the vac pods)interchangeable? Never messed with a Mopar distributor so any help would be appreciated.
