Resto_1
Looking for a correct AFB for a Non Hi-Po 63-66 383 with auto trans. Not sure if the same carb is used on std 4-bbl applications as is used on Hi Po application. Carb from a non police C-Body would be correct. Note California carbs were different due the Cleaner Air Package. If anyone has the Carter numbers, that would be helpful too. Also a stock intake manifold. Thanks in advance
