greenmachine
What’s the bad boy alt people use. My tuff stuff sucks.
In what? Application pleaseWhat’s the bad boy alt people use. My tuff stuff sucks.
69 net. 440, new harness, bee cool radiator with 30 amp each fans. Keeps blowing fuses per tuff stuff my “high output” alt can’t keep up.In what? Application please
How do you have your added loads wired? Which Tuff Stuff alternator are you running? What fuses are blowing? 60amps of fans? Has that been measured/confirmed as the actual current draw for the fans?69 net. 440, new harness, bee cool radiator with 30 amp each fans. Keeps blowing fuses per tuff stuff my “high output” alt can’t keep up.
The fuse will not blow from output. BUT your light bulbs will, however only the light bulbs that are on. Ask me how I know.An alternator won’t blown any fuse by its output. Not even by a high voltage failure. Fuses don’t blow by voltage but amperage and this is requested by the devices, not pushed in by the source. Diff stuff is an internal fail causing a short, but in that case the fail will be different.
