Aftermarket Sway Bar Brackets
JR_Charger
4:16 PM
____
Top is UMI #0047, bottom is QA1. The smaller bar I got the UMI brackets for is enough to bend the stock brackets on a 240 hp FWD Buick, allowing the mounting bolts to pull out of the frame. Are the QA1 brackets really enough to handle the bigger bar? I'd go ahead and use the UMI brackets on the Charger but the QA1 bushing doesn't quite fit (it's so close, but it doesn't). The QA1 bushing appears to have a 27mm hole, perhaps someone has a 27 mm bushing that will fit the #0047.
The UMI bracket is 1/2" taller than the QA1, not including the zerks. Possibly a problem if mounting the bar under the k member.
