Hello:
My car has the ever popular no brand name 3 gauges under dash pod. This particular set has a AMMETER, OIL PSI (not electronic), and TEMP.
To get the ashtray out, I had to take the two of the gauges out of the pod to get the ashtray screws out (at least they did not drill holes to install).
ANYHOW, the temp gauge has a very thick line connecting to the back of the gauge. The line has a brass tube that is sort of pressed into the nut. This brass tube came loose, so when I gently pressed it back onto the nut I heard a POP. Not sure if I damaged the gauge as I did not connect the battery and start the car tonight.
I know some of the really old style temp gauges had a glass bulb in them as sort of a thermometer. Assuming I damaged the gauge, what is a good replacement?
Thanks for any help and/or comments. Take care, Bill
