j-c-c-62
You are reading 220 at the engine, which I suspect we can agree is on the hot side and can be defined as a hot engine, as it's an engine attached part, and less than 24"? away on radiator inlet hose you are reading 180 which is the normal part, that variation is indeed "magical" and the dilemma here I suspect. Let me toss in a little math to spice things up, that is a 40 degree unexplained measured temp drop in a very short distance of normal plumbing.220 degrees at the pump housing is normal?
Reading is certainly one aspect here, and reading comprehension another, while we are tossing jabs about.
